Trane xv90 new board issues
I replaced the board and transformer in my Trane xl90. Now I am getting the 3 flash diagnostic code from the new board. On the back of my cover it has that as “induction motor error”. On-line what I am finding is the more generic “pressure switch fault”. The induction motor was replaced 3 years ago and spins fine. Nothing happens other than the light flashing 3 times, the inducer motor does not even try to start. Am I correct that the inducer motor should start before the pressure switches are “active”? I did bypass the normally closed inducer limit switch too eliminate that as a fault.
What condition would I get this situation?
Thanks in advance for any and all answers!
