Mobile home Coleman gas furnace
Old 11-22-21, 04:47 PM
K
Hello, i got a question, i recently replaced my draft inducer motor and had to pivot the burner (i think that's what its called) to be able to put the new draft inducer in but my gasket for the burner deteriorated over time.. i need to know if i can use high temperature silicone to seal it because im without heat and it'll take a few cold days for the fiberglass gasket to get here.. is it safe to do that? If not what can i do to seal it so no natural gas leaks out? Do i seal them both by chance? This is my first time doing this and i dont have a clue. Thanks for your time and help.
Can i Seal this with high temperature silicone?
Top
Bottom
