XE80 won't produce heat
Old 11-28-21, 04:45 PM
The inducer fan motor kicks on. Followed by the flame igniter, all four burners kick on then two seconds later tit shuts down. The flame sensor and gas valve are knew. My indicator light flashes fast continually until it finally flashes on twice because it's in shutdown mode.
Any close as to what could be the problem?
Old 11-28-21, 06:54 PM
Received 3,416 Upvotes on 3,063 Posts
Welcome to the forums.
XE80 is not a model number. It's inside on the side wall near the burner on an ID tag.
You need to get the fault before it goes into lockout.
It should try to light three times first.
If you aren't getting three attempts it may have a defective control board.
Does the board have a flame sensor LED on it ?
If not should confirm the flame sensor current with a ua meter.
There are many videos on you tube illustrating it.
