New house, a lot of questions - Starting with HVAC
Old 12-14-21, 12:50 PM
D
Hey all, first post here (yay), and I have some questions regarding my HVAC.
Everything is located in the mechanical closet in the basement. The furnace, and what I assume is the return, sit on top of a plywood base. I've confirmed the base is pulling air in from the gaps between it and the concrete floor which just sounds sketchy and a no-no from my perspective, but I am not a trained HVAC technician.
Looking for help and advice (also, let me know if I need to be in a different sub).
Picture attached for reference.
Old 12-14-21, 03:18 PM
Marq1's Avatar
Received 1,099 Upvotes on 999 Posts
Sure there may be some gaps there, no more than any of the joints in the duct work, but I bet a majority of the air is coming down that big duct on the left side!
Old 12-14-21, 05:41 PM
D
While I don't disagree, I had a thought that concerns me more.
There is a whole home humidifier upstream of that wooden plenum... Isn't that a little dumb to be introducing water into a cavity upstream of wood?
I'm assuming the inside is unprotected given I know air is being pulled in from the floor.
Old 12-15-21, 12:08 AM
Marq1's Avatar
I've had, and seen, applications like that, using wood framing to support the HVAC equipment it's pretty common for homes build on slabs.
Remember, your introducing humidity, not water into the air so it's not like the wood is getting soaked.
It's always good to seal openings in your system, caulk the joint on the floor, use electrical putty to seal openings in ducts, Mylar tape on seams, makes for a more efficient system.
Old 12-15-21, 09:50 AM
Received 3,415 Upvotes on 3,063 Posts
Interesting installation. Typically there would not be a wood base and the return ductwork would go directly into the bottom left side of the furnace. Doesn't matter if it's on a slab. Same installation slab vs basement floor. Usually a box like that is used if there is an additional return connected to it.
Although it's not ideal to have the humidifier on the return side.... it's usually ok.
Old 12-15-21, 09:56 AM
Marq1's Avatar
The couple homes we had in CA had the "box" because the upstairs return air came down via the duct and the downstairs return air came into the box without any duct work.
