hvac noob, help id something
Old 12-17-21, 09:35 PM
Hi all,
trying to accomplish a few things but need some help identifying the "vent thing" in the middle between the furnace and the hot water heater:
We have a heat pump - is this for the heat pump?
Thinking of replacing the heat pump for a traditional furnace/AC combo. If that middle thing is for the heat pump, does it go away if we replace the heat pump?
Old 12-17-21, 09:40 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
Not exactly sure what you are referring to.
Your gas furnace is on the left. Directly to the right with all the white paint is the return duct
to the furnace and then the hot water heater.
You have a dual fuel system.... gas furnace and electric heat pump.
Old 12-17-21, 09:46 PM
T
Received 65 Upvotes on 60 Posts
Not sure what your referring to. The shiny galvanized "T' at the top of the picture with the barcode sticker?
Edit: PJ probably nailed it....
Old 12-17-21, 11:26 PM
Thanks for the quick replies. Yeah, I guess I wasn't terribly clear, the item in question was the vertical duct with the white paint on it.
Is there a rule on how close the water heater can be to something like the return duct? It's really hard to tell from the camera angle, but there's about a foot of space between the two and I'd like to shift the heater over by about 8 inches. Aside from doing some duct/pipe work, any issues with putting the return duct and water heater 4 inches apart?
Old 12-17-21, 11:48 PM
4" between the return duct and the water heater would be fine.
Old 12-18-21, 02:33 AM
Marq1's Avatar
Received 1,104 Upvotes on 1,004 Posts
Not really the best place to store stuff, especially if any of that paint is flammable.
