Condensate Pump
Condensate Pump
Carrier 59TN6A
Installed 1/2015
Woke up this morning hearing pump running constantly, water on floor.
It usually runs maybe 20 seconds.
With the pump removed when the furnace is running I'm getting a pretty
steady drip into my water basin. This okay till I order a new pump?
Thanks very much
Installed 1/2015
Thanks very much
Condensate pumps last a long time. When they stop working it is usually a clogged line or the sump needs cleaning. Before ordering a new pump I would open up yours and see what the reservoir looks like inside. Also, blow air through the discharge line to make sure it's not clogged.
Baldwin
voted this post useful.
Right you are, it was a clogged check valve. Thank you.
After a few videos I managed to get it cleaned up so it works.
The reservoir had the most awful slime in it, that was an adventure cleaning.
This is my first time having a high tech furnace, lots to learn.
Thanks again.
Thanks again.
I clean my condensate pump every couple years. My house and in my rental houses condensate reservoirs all grow the nastiest blob of snot. Luckily it's easy to remove and clean.
