TG9S horizontal install condensate drain air gap
Old 01-26-22, 09:29 PM
F
I have a York TG9S furnace. I've been dealing with the 3 blinking light issue for a number of years. Come to find out that the no-good tech that replaced the condensate pan 4 years ago, installed the wrong one. My furnace requires a 0.88 inch orifice in the condensate pan, but the one he put in only had a 0.80. Further, he left many of the ports unplugged, and lots of sagging in the pressure switch tubes.
So now that all of that is fixed, and I put in the right condensate pan... I also decided it would be best to add an air gap to the condensate drain. However this is sort of a unique challenge with a horizontal install. The drain comes right out of the bottom. And due to my install being in the crawl space, there is not much room to work with.
The picture below is what I ended up doing. I drew in red the tee and open air pipe I put in. This extends just above the internal trap of the condensate pan. Any plumbing or HVAC experts out there care to grade me, and let me know if I did OK? Or if this can be improved somehow?
Old 01-27-22, 12:26 AM
Received 3,423 Upvotes on 3,069 Posts
Welcome to the forums.
You only left the generic model group.... not the model number.
Have you consulted the York installation manual ?
Wasn't sure your exact install without knowing the size of the furnace.
TG9S* installation manual - pdf
Old 01-27-22, 06:19 AM
F
Good point. Here you go: TG9S080B12MP11A. The install manual does have an example for a vertical install where the drain comes out the side. But I haven't really been able to find an example for a horizontal install.
Very interestingly, I did come across the article listed below. Looks like some tech, somewhere, installed a tee and a vent in the rubber drain hose INSIDE the furnace cabinet. That sounds just crazy to me.
https://ghac.makekb.com/entry/22/
