Furnace cover
Old 04-10-22, 10:09 AM
CluelessOwner's Avatar
Post Furnace cover
This is my first time up in the crawlspace and looking at the furnace.
This looks like the cover but it has aluminum tape around the edges. I don't want to mess up so I stopped here. I would like to check the capacitor and the motor in this thing.
Old 04-10-22, 12:38 PM
Received 3,422 Upvotes on 3,068 Posts
Hmmmmm..... not a big fan of crawl space installs.
I labeled your picture for easier discussion.
Has this ever been professionally serviced since you've been there ?
That looks like a flex line on the flue. There are many types of flex pipe like that and most are not rated for that type of use. Most techs know by looking at it. Typically flex is not used in that type of situation as it's very close to combustibles and hard to keep straight. Proper pitch is important for flue gasses to be vented out.
You need to remove the burner door to get the blower door off.
The red tape should not be there and serves no purpose.
The orange needs to be removed to get the burner door off.
The green needs to be removed to get the blower door off.
I'm guessing the tape was put on there because the furnace was sucking in crawl space air and carrying it throughout the house.
I'd like to see a picture of the burner area when you remove the cover.
CluelessOwner voted this post useful.
Old 04-11-22, 05:15 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
I think that is corrugated duct work for the flue pipe, more pics would be helpful, just curious why you need to check the capacitor, is the blower not running?
Geo 🇺🇸
Old 04-14-22, 11:25 AM
I turned off the gas and electricity to the unit just in case. I was able to remove the cover thanks to your help.
I replaced the capacitors and AC condenser fan motors when one of them failed last year. This unit is 16 year old so I just want to look up the parts just in case both blower units stopped working in 115 degree AZ heat.
Old 04-14-22, 11:43 AM
Everything is clean and looks pretty good. I'm not sure on that flex line for the flue.
Old 04-15-22, 08:01 AM
How long do the capacitor and blower motor last ?
I don't know about the flex line but they do sell them around here. I live in Arizona and we use the gas furnace 2-3 month max. I guess this is why it looks fine for a 16 yr old furnace
https://www.homedepot.com/p/DuraVent...317090780-_-N&
Old 04-15-22, 12:03 PM
Good to know on the flex pipe.
There is no set or "advertised" age for blower motors and their caps.
I've seen them last well over 25 years and still be operating normally.
