Thermopride oill furnace needs to be reset after not running for a while
Old 10-09-22, 05:12 AM
1
The furnace repairman is perplexed. If I turn it on at the thermostat it's fine. However if it hasn't run for a while it won't turn itself back on and I have to go down and reset it. The cad and the eye are new the flame is bright and the right color - all the right stuff is happening.
Could this be a bad thermostat?
Old 10-09-22, 06:29 AM
R
Received 185 Upvotes on 169 Posts
No, itís not a thermostat problem. Sounds like it may be starting to loose prime.
When was the last time the furnace was cleaned and adjusted?
Old 10-09-22, 09:36 AM
Received 3,424 Upvotes on 3,070 Posts
Welcome to the forums.
As mentioned.... not a thermostat problem.
When the burner reset trips.... the problem is burner related.
