Furnace won't ignite. Honeywell
Old 11-19-22, 05:22 PM
Help. Honeywell r7184b won't ignight
Old 11-20-22, 06:15 AM
Tolyn Ironhand's Avatar
Received 675 Upvotes on 573 Posts
What is it doing? Is the igniter glowing? Does it ignite and then go out right away? Does it ignite and burn for a while and then go out?
Old 11-20-22, 07:44 AM
R
Received 185 Upvotes on 169 Posts
That’s an oil burner primary control. When was the last time your oil furnace was cleaned and PMed?
Have you pushed the reset several times? Do you know doing so creates an explosion hazard?
