Furnace Draft Inducer
Old 11-20-22, 02:19 PM
P
Hi all, I have a Carrier gas furnace Model# 58PAV090-14, Series 161. My draft inducer wheel (the little black one with rotation stamped on it) was making noise and every now and then it would scrape something so I looked and it was riding up and down on the motor shaft and scraping the lock washer; so I pushed the washer on tighter and oiled the shaft with 3in1 oil. Now the wheel doesn't spin at all, I can spin it with my finger easily and also spin the shaft of the motor easily, do I even need that wheel to spin if everything is working fine?
Old 11-20-22, 02:22 PM
Received 3,422 Upvotes on 3,068 Posts
No sure what wheel you are referring to but some draft inducers have a small fan on the back to keep them running cool.
Houston204 voted this post useful.
Old 11-20-22, 03:12 PM
P
I added 2 pictures
Old 11-20-22, 03:23 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
https://www.repairclinic.com/PartDet...IaAvtwEALw_wcB
That part is only 13 dollars..
The product number is a more accurate way to look for parts than the model number.
-16114 or -16116?
I guessed -16116 in my search.
Old 11-20-22, 03:30 PM
That black wheel is the fan that keeps the inducer cool.
I've never had one loosen up.
I thought it was keyed to the shaft...... but maybe not. Hard to tell from the service pictures.
If you push the fan on the shaft hard enough it will bind on the motor.
You either need to come up with a way to stop that or replace the blower wheel.
Based on shaft size there are several replacements.... inducer cooling fan.
peglegpiney voted this post useful.
Old 11-20-22, 04:43 PM
P
Thanks, I ordered a new cooling fan wheel, and yes Pjmax it is keyed but it is also the only plastic part in the furnace and I think it just wore out so now instead of having one flat side the whole thing is round and doesn't grip the shaft.
Old 11-20-22, 05:20 PM
Houston204's Avatar
I've had to replace those cooling fans a few times on the 58PAV and 58RAV's.
It's a good furnace but the early model had an edge pin connector that was prone to corrosion,
The replacement board was an expensive kit that addressed this issue.
Old 11-23-22, 12:54 PM
P
Ok, the new cooling wheel is here, my question is how far away from the draft inducer should I place it: half an inch, one inch, 2,3 maybe 4 inches; and when I put the internal tooth lock washer onto the shaft does it go just at the tip of the shaft or how far away from the fan wheel should I push it to? Thanks
Old 11-23-22, 01:05 PM
Typically the motor shaft is only flat to a certain point. Not all the way to the motor.
The blower wheel should be pushed until the flat point ends and the star washer gets pushed
all the way against the wheel.
Old 11-23-22, 01:14 PM
P
thank you
