ICP furnace issue
Old 11-22-22, 05:09 PM
T
ICP furnace issue
I have been trying to troubleshoot a furnace for my daughters boyfriend. The furnace goes through the ignition sequence, burns for about a minute and shuts down. It will go through this cycle three times and goes into a safety lockdown for an hour. It flashes a pressure switch error code. It has a dual pressure switch that appears to test ok. I switched it with a new switch and saw the same behavior. We found that we could make the furnace run by by-passing the high pressure side of the switch. I did this with the original switch and the replacement. My voltmeter tells me the original switch is working as designed. I have been consulting a couple other people and we are all kind of at a loss. Why will the furnace run with the switch bypassed but not with a seemingly working switch? I have checked the exhaust vent pipe, it is clear. I have checked the condensate trap and it is good. What else could be causing us this issue? Thanks in advance.
Old 11-22-22, 06:03 PM
Received 4,050 Upvotes on 3,633 Posts
Welcome to the forums.
ICP makes a lot of furnaces. A model number is required.
Old 11-22-22, 06:13 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
I recommend getting a dual port manometer and teeing into both tubes to measure the vacuum at the pressure switch.
Old 11-22-22, 06:26 PM
T
It is model N9MSE0401410A2
Old 11-22-22, 06:37 PM
There are a few service bulletins on that series. A serial number is required.
Check here..... n9mSE service bulletins
Old 11-25-22, 09:17 AM
T
The bulletin about drilling out the vacuum port of the induction motor seems to have remedied the situation. Thank you for the assistance!
