Installing 2 ecobee3lites with HZ311 controller
Quick question, I have installed a couple of ecobee3lite thermostats using the PEK and installing at air handler so have some knowledge. I am installing 2 on a system with a Honeywell HZ311 controller and no C wire. My question is do I need to install a PEK for each thermostat and should that be done on the controller at t=stat connections?
Thanks
Thanks
I don't use the power adapter. I run new cable.
If you don't have enough wires to carry a C then you need to use a PEK and it goes at the EIM.
