Trane XT-95 furnace blows cold air after 15 minutes
Old 12-14-22, 09:19 PM
E
Exclamation Trane XT-95 furnace blows cold air after 15 minutes
Hi. Could you help me with this problem?
My Trane XT-95 furnace blows hot air at first, then blows cold air after approximately 15 minutes.
Diagnostic light blinks 3 times, indicated pressure switch error, then I replaced the pressure switch, no dice.
Today, I replaced 3'' limit switch, no dice.
Should I buy flame rollout switch and try? Thank you.
Thanks and happy holidays
Old 12-15-22, 01:45 AM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
XT95 is a group number. Please post the complete model number off the ID tag.
The three flash code should indicate a pressure switch opening.
A good pressure switch will not operate 15 minutes and then fault. It sounds like you have a clogged condensate drain or water in the inducer getting into the pressure switch line.
It will not be a flame rollout issue.
erictom voted this post useful.
Old 12-15-22, 11:23 AM
E
Thanks for your reply, Sir.
The model number of the furnace is 4txfh054cc3hhaa.
Seems like the condensate drain line is clogged. I tried to put some bleach and drain cleaner liquid into the
line, I didn't see the line outlet under the eave dripping...
How can I do next?
Many thanks
Old 12-15-22, 06:45 PM
E
Hello~ I just uncloged main & 2nd drain line, problem still exists. Hot air blows for 15 minutes, then cold air.
By the way, I have Honeywell HZ322 zone controller, do I set heat fan controlled by HVAC or Panel?
When I turn on the heater, blows cold air first, then hot air, then cold air again after 15 minutes. Error: 3 flashes,
pressure switch error.
Thanks!
Old 12-15-22, 11:02 PM
You left the model number for the air conditioner coil.
Take the burner door off..... the ID tag will be inside on the side wall near the burner.
I'm surprised you didn't see it working in there,
Old 12-24-22, 05:21 PM
E
Hi. thanks! The correct model number is tux1c100a9h41bb.
The Trane furnace problem exists, flashes 3 times, I tried new pressure switch sensor, no dice.
Could you give me more hints? Merry christmas !
Old 01-12-23, 12:49 PM
E
Hi Sir. thanks! The correct model number is tux1c100a9h41bb.
Thanks!
Old 01-13-23, 03:55 AM
R
Received 185 Upvotes on 169 Posts
Sounds like a condensate issue. Or problem with the venting.
