What is the important part of numbers on limit switch
Old 12-15-22, 08:25 AM
C
What number do I use to order new one?
313245
t-0-d 60t11
s0628
l-150-20f
Old 12-15-22, 08:36 AM
coolmen's Avatar
Received 4 Upvotes on 4 Posts
The limit switch is the Most Important safety devise!!! Dont ever bypass it .
150-20f 150 would be the temp it will open and shut off burner with a 20 degree reset.
Old 12-15-22, 08:54 AM
Received 3,422 Upvotes on 3,068 Posts
A furnace model number and picture of the old part are very helpful.
We know that's a blower switch.
The previous member listed the temperature but the case type is in question.
How to insert pictures.
The numbers on a part are not necessarily a part number.
313245 is an older limit switch. I show this as a replacement.... 313245 - replacement
chuck Stan voted this post useful.
Old 12-15-22, 11:44 AM
C
My limit switch.
My Trane limit switch 315524 21 Disregard all previous numbers in orig post.
How can I order a replacement?
furnace model s8b1b060m3psaaa
Old 12-15-22, 10:40 PM
Sorry.... you need to double check the model number. It is not listed as written.
The part numbers are stamped in the metal.........
Old 12-16-22, 08:28 AM
C
I can assure you that is my model number.
Old 12-16-22, 08:31 AM
C
Why look for stamped part number? It is written in plain view in the white circle.
Old 12-16-22, 01:41 PM
You'll need to contact a Trane parts retailer.
Old 12-22-22, 11:46 AM
C
Figured out my problem.
Furnace was short cycling. Put in new filter and cleaned flame sensor. Didn’t help. At first, burner was cutting off once then starting again. As weeks passed It cut off twice, then three times, and fourbefore restarting and reaching set temp. Searched for new limit switch but could never find correct one. Tried to test switch by running without filter just one cycle. It worked correctly. Had been running a FFR7 filter for 6 months. Bought a FFR5 filter which looks exactly the same. Furnace now runs fine. Thought the FFR numbers referred to quality of filter not filtering ability. How much did I save for service call and new limit switch, 400?
