Ecm motor controller
Old 12-17-22, 11:39 AM
C
My ECM blower motor has 4 programmed speeds that are selectable by providing one of 4 ac voltages (0,-12,+12,+24).
Does the 0v signal select the lowest programmed speed and +24v select the highest programmed speed?
Old 12-17-22, 11:43 AM
Received 3,415 Upvotes on 3,063 Posts
Welcome to the forums.
Are you sure that it takes multiple DC voltages ?
Typically there are multi speed taps that are 24vac.
Selection of the correct tap denotes speed.
ECM blower speed selection
I need a model number or unit wiring diagram to comment further.
