I have a Weil Mclain GV-5 series 1 gas fired boiler. I want to replace the boiler fed indirect tank with an electric hot water tank to allow me the benefit of the recently installed solar panels. The gas bill keeps going up and our electric bills are locked in at a minimal cost. Can I cap the feed and return lines feeding the Indirect tank and disable aqua stat Weil Mclain GV-5 with Indirect
relay for the indirect We have 4 zones with dedicated circulating pumps.
It's do-able. It's not just capping off here and there.
I can see some major re-piping needing to be done.
Fresh water feed and boiler makeup come into storage tank and will need to be addressed.
I just swapped out to a R7184B for a R7284 resideo oil primary control. I have attached all the wires which have been color-coded identically to the original controller. However, when I call for heat, I get no ignition. I know all the wiring is correct because the original well controller still works however, the new one does not ignite at all so I wonder if there is a setting I am missing, I have attached some pictures. Please let me know if anybody has suggestions. This is an Beckett oil hot air furnace.
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/f3fd3b00_eb93_4155_9a15_b0fd6892a090_025f5c82fa2ef9ccb9fb6548c9365a08f87ca201.jpeg[/img]
[i]Wiring of new controller[/i]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/0190b88f_e76c_49df_bac1_f9a69fd2ab25_c61d983276c05fadc09de223fc9cadc274a17a15.jpeg[/img]
[i]Oil burner[/i]
Working on a Coleman Evcon natural gas furnace in a mobile home not lighting / igniting. The circuit board has an LED flashing once indicating ignition failure. Thinking maybe a bad igniter or something. Any troubleshooting guidance greatly appreciated.
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/a8ac1629_ac8a_4408_9460_f11d87476e68_4934efcf1145fe078e54b982bb4bd8b97b5928ff.jpeg[/img]
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1140x2000/a8302da5_2adf_4f9d_883c_fd2db6db5f84_c1e3a683c9c5c0234d32f9da93ee872a7e8c5770.jpeg[/img]
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/a9b0eb9e_b4b8_4641_87b3_657fbc408cf5_d760e0de4e809b0dda30bb46fbf58e4d9ec417d7.jpeg[/img]
[i]Thinking I need to remove this to get to igniter?[/i]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/9709dce6_26be_43b4_921f_eeb76d15cfff_84181a4455911eac7a2723e8034241a7c34e030f.jpeg[/img]
