Igniter or Pressure switch?
Happy New Year folks.
Question on Goodman furnace, which decided that it would not work for the new year.
T-stat clicks on, inducer motor starts, after a few seconds I hear a click which is usually followed by the glow from the igniter, but that does not happen. After a few more seconds, everything shuts down and I get a faint smell of gas.
Is this behavior is consistent with (a) igniter or (b) pressure switch
TIA
TIA
Can you post a picture of the ignitor?
If you can see an obvious crack in it you need a new one.
A non contact volt stick is a great tool for checking for voltage to the ignitor.
You won't get gas with a pressure switch lockout.
That looks like the igniter from my old Luxaire/York furnace. (they are more fragile than eggs.)
You have an igniter problem. It could be a defective igniter or it could be the control board.
You need to use a meter to check for 120vac on the igniter when it should be heating.
Houston204
voted this post useful.
Thank you
Much appreciated. I thought it was the igniter because I smelled gas.
This Goodman is about 20 years old and original to the townhouse.
Since you guys do this for a living…..
If this were your home and you were replacing, the system because of age, what would you replace with and what is a good ballpark number? I’m in NJ.
Pretty sure the furnace is something like 45k BTU and the AC compressor is 2.5 tons. The townhouse is 2 floors and 1900 sqft. Both heat and AC work ok in normal weather and struggle a little in extremes, but I understand the builder designed for certain limits. Can’t really complain about that.
Thanks again
Thanks again
Hard to say without knowing more about the duct work. If you are running a great external static pressure (.5 or .6" w.c.) then a 2 stage outdoor unit with an ecm indoor blower 2 stage furnace is an option to consider.
If you are running high external static pressure (~.9"w.c. or above) then keep a similar setup.
