gas furnace turning on and off
Old 01-05-23, 07:40 AM
B
I have a gas ( propane ) furnace in my home ( attic ) and it keeps turning off and on ( short cycling ). Replaced the flame sensor but is still doing it. Thanks....... Steve
Old 01-05-23, 08:18 AM
P
Received 1,759 Upvotes on 1,572 Posts
If you tell us what furnace you have (brand AND model number) we can offer more specific advice. Check the switch for the exhaust blower. They often clog or quit working and will shut down the furnace.
Old 01-05-23, 09:10 AM
B
Received 234 Upvotes on 207 Posts
Odd that furnace will restart (assuming tstat calling for heat) once it shuts down due to change in state from closed to open of exhaust blower sensor. Most controls require a exhaust blower sensor change in state from open to closed for the furnace start up to continue. Is your problem with both start up and shut down?
Old 01-05-23, 10:51 AM
B
The model # is gmp075-4 ( Goodman ). It starts up ok and runs fine for the first minute. Then will shutdown and start up again over and over again.
Old 01-05-23, 05:33 PM
R
Received 183 Upvotes on 169 Posts
The GMP furnaces had known issues with the heat exchanger. Pull the blower and inspect the crimp rings at the bottom of the cells before continuing. If they are popped off you’ll need a new heat exchanger or new furnace.
What error is displayed when it fails?
Does this unit have a propane pressure safety switch?
Old 01-05-23, 05:39 PM
Received 3,415 Upvotes on 3,063 Posts
That was a problem with the gmp075-3's. Same problem with the 4's ?
Gray man gmp video
Old 01-05-23, 05:41 PM
R
Same crimp ring design in all the GMPs to my knowledge.
Old 01-05-23, 08:44 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
Count the LED blinks visible through the furnace panel.
Old 01-08-23, 11:49 AM
B
Upon further review it was the blower motor turning on and off. Status light on, no blinking. Took the limit switch out, blew it off, pushed it in a few times and put it back in. Works perfect now. Went ahead and ordered a new limit switch anyway. Thanks everyone for the advice, much appreciated......... Steve
