Gas Fireplace Repair
Old 01-16-23, 07:55 PM
I just changed the pilot light assembly on my gas fireplace. In the attached photos there is a hard black substance at the bottom of the assembly on the old part that is used to seal the holes where the lines go thru. There is a photo of the holes after it was removed. I put the new assembly in. I'm wondering if it's necessary to reseal them and if so what is used to do that? It looks like it used to be some sort of putty.
Second issue! There is a photo of the brass tip that inserts into the burner assembly. On the burner assembly tube that goes over the brass part you will see an open slot. There is one on the other side also. That tip can be rotated so that the holes are covered or closed. What is the purpose of having those holes there? The brass part doesn't go very far into the burner tube so it seems to me that there would be gas escaping before it went into the tube. When I turned the fireplace on to test it, it seemed like the gas wasn't immediately spreading throughout the burner assembly. Any help or a bit of education on this would be appreciated.
Old 01-17-23, 01:32 AM
Received 3,419 Upvotes on 3,065 Posts
It looks like electricians putty but that is only rated to approx 120f.
I have silicon seal on a roll similar to this high heat putty.
I also use Permatex red high heat silicone. permatex red
You can get the red Permatex in many home improvement and auto parts stores.
You don't need a lot. Just a thin amount to seal the holes.
Do you know what a venturi is ?
In the picture is the brass orifice.
It has a tiny hole in the end where the gas comes out under high pressure.
As the gas passes thru the burner it picks up air thru the shutter.
That's the venturi effect.
Your stove top, oven, etc all work the same way.
The shutter is adjustable to get just a bit of orange in the flame. You want mostly blue.
mickeyrory voted this post useful.
Old 01-17-23, 08:06 AM
PJMax,
Thanks for the information. Just what I needed!
Old 01-17-23, 01:40 PM
PJMax,
After getting everything back together and turning the gas on I have a slight leak somewhere that I can't pin down. When the main source of gas is on and the gas for the fireplace itself is off there is no detection of gas anywhere, so I can eliminate the leak at the supply side. When I turn the gas on at the fireplace my detector beeps and I do get a scent of gas when I put my nose close to the area. Question! Of the three connections I made--would it only be the thermocouple and pilot light connections that could be the source of the leak? I bought the Permatex red along with some liquid leak detector and after putting that on I haven't seen a bubbling that would tell me anything. I can't imagine it would be normal to have any amount of gas leakage, even low, so I'll ask, "is it common or do I continue searching?"
Old 01-17-23, 01:48 PM
When the main is off..... all ok.
When the main is on but the off-on-pilot is off ..... all ok.
When you turn the off-on-pilot control on.... there should be no gas smell.
There should not be any gas flow to the pilot until the valve is in pilot and you are holding the pilot button down. If you light the pilot and it's lit.... and you smell gas.... it's the pilot tube gas line where it connects to the valve.
Old 01-17-23, 02:18 PM
Forgot about the off-on-pilot. It has been in the off position.
I'm assuming by main you mean the on/off for the fireplace itself and not the on/off in the wall.
When the main is on but the off-on-pilot is off ..... I get the leak.
When the main is on and I turn the off-on-pilot to on ----I get the leak
When I turn it to pilot and hold the button in I detect the leak.
I have lit the pilot and I detect the leak.
I suspect it is the fireplace side of the on/off valve because the detector doesn't take long to beep when I hold it there. If there shouldn't be any gas flow to the pilot until the button is pushed would that confirm that the leak is right there in that on/off valve? I was disappointed that the liquid leak detector didn't bubble anywhere.
Old 01-17-23, 03:07 PM
Then the leak is between the service valve(s) and the fireplace valve.
It would pretty rare for the fireplace valve (off-on-pilot) itself to leak gas in the OFF position.
Old 01-17-23, 03:42 PM
Sorry PJMax, it must be a trial talking tech to a layperson. I'm going to replace the service valve because I place my gas detector tip right next to the valve and as soon as I turn it to on it takes about three seconds to beep. That is with the fireplace valve in the OFF position. Thanks for your patience. I appreciate the education at your expense.
Old 01-17-23, 04:06 PM
No problem.
The problem is trying to change a valve. Hopefully there is a union because without one it's very hard to change an item in the middle of the run.
Old 01-17-23, 06:36 PM
It was a flexible gas line, with good movement on both sides. I bought a new shut-off but decided to try the old one with some new sealant. It worked, so it was a leak thru the threads on one side. I know too well the issues with repairing plumbing pipes when they are inflexible. Good old sharkbite! Again, thanks for sharing your expertise in this.
