Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Gas and Oil Home Heating Furnaces
Reload this Page >
Goodman Furnace (7 years old) Flame sensor needs to be cleaned about 1 time per
Old 01-22-24, 09:18 AM
B
Goodman Gas forced air furnace (Sorry don't have model info with me currently). Approximate age 7 years old. Flame sensor needs to be cleaned approximately 1 time per week, during initial fall/winter season. Seems to work fine when outside temperature is under 30 degrees. Needs cleaning more so when warmer outside temperature. I suspect humidity in basement (which is high) is causing this issue. Going to try dehumidifier in furnace room this spring. Anyone run across similar situation? Does my reasoning seem on the right track? Grounds wires all tight and secure. Thanks
Location MN
Old 01-22-24, 09:35 AM
P
Received 2,319 Upvotes on 2,064 Posts
That is not a normal problem. My rental houses had furnaces outside and in unfinished basements with no issues regarding the flame rollout switch. Any time the flame rollout trips I give the heat exchanger a thorough inspection.
