Change blower speed on furnace for cooling season
Old 06-15-24, 12:54 PM
L
uxaire Unitary Model G8C10016MUC12H - 100k input/80k output
A-Coil - MC36C2AH1A Serial# A0L6074298 (3 tons)
guys - may not be visible on the am I right that the black wire on the bottom left is going to a density that says cool and brown says heat
1. does this mean currently my cool is set to high and heat set to medium high?
2. I canít find a low switch that Iíd like to attempt for the cooling season
Thanks
Old 06-15-24, 01:24 PM
Received 4,152 Upvotes on 3,729 Posts
Yes.... that is correct.
I see.....................
black = high = cool
blue = medium = heat
red = low = park
You can't randomly slow down the blower especially on A/C.
You run the risk of the coil freezing.
You can make a Y cable and connect blue to cool and heat.
The black and red will be not used.
Old 06-15-24, 01:38 PM
L
Unfortunately, I have a 3 ton a-coil which is installed in the attic and just servicing the second floor, which is only 500 ft.≤ so obviously massively oversized. It does cycle every 5 to 7 minutes and not really removing humidity in this climate zone 4
1. What is the point of the Y cable?
2. I donít see a red cable, but I do want to attempt connecting cooling to low if you can guide me. I do understand the risk of this, but I only operate the air conditioner perhaps 15 total days in the summer. So far I already connected cooling to medium-but it only seems to make a marginal difference
thx
Old 06-15-24, 02:42 PM
According to the schematic you posted.... there should be a red wire.
Go to the motor and see what colors are there.
Red will probably be too slow for A/C.
Old 06-15-24, 03:02 PM
L
How much is the usual CFM difference in % between high & medium and medium & low?
For additional context, I have 2 large returns connected to this unit and it breathes very well
Old 06-15-24, 04:22 PM
Not sure what the speed difference is.
There is detailed info on the wiring diagram but it's too small to read.
Old 06-29-24, 01:40 PM
Received 18 Upvotes on 18 Posts
You have a 3 ton evaporator coil but what size is the outdoor condenser?
