Smell coming from central air unit
Old 07-30-01, 01:00 PM
Guest
Exclamation
Lately, I have noticed a smell coming up through the vents whenever the air is running. It smells like rotten eggs. About 3 weeks ago, the coils(?) on the unit (inside the home) froze over. Once they thawed, the water drips inside a pan. Could this water be causing this smell? I've already changed the filter, and it doesn't seem to help. Thanks for any assistance you can provide.
Old 07-30-01, 03:07 PM
PDF
You need to
Shut system down,remove panels from inside coil,clean evap coils,flush and clean evap pan.THEN use a bleach solution to sanitize both coil and pan.There is "STUFF" growing,it has gotten wet,and has activated itself.PDF
Old 09-01-01, 10:38 AM
Guest
Hi Again, I need to know what I can do about grouting that is coming up between my ceramic tiles. Is there a product that I can use to seal it or do I have to regrout?
Thanks for your help,
Claudia Walas
