screws
Old 08-10-01, 05:15 PM
G
Guest
Question
Hi
i'm trying to have an air conditioner installed in my window or any room in the apartment. I have screws in them that can be screwed tighter but not loser even with the special screwdriver.
Can someone help me!!!
Thank You
bonnie1322
Old 08-11-01, 08:39 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Suggestions
Hello Bonnie1322
I noticed your question remains unanswered after having been viewed several times.
As I interpret your question, your having difficulty opening the window do to security screws being installed in the windows and not a question relating directly to the window A/C unit.
If this is correct, might I suggest you ask this question in either the "Fasteners" or "Doors and Windows" Forums.
I am sure by doing so, you would get the advice of the professionals in either of those forums to assist you.
You might also want to ask the apartments owner or building management how to remove those screws.
Regards & Good Luck
A Forum Moderator
Tom_Bartco
