Can I install the central AC outdoor unit myself?
Can a central AC (outdoor unit) be installed by a non-professional person like me? What tool and/or knowledge do I need? I am the "doityourself" kind of person. Thanks
I used to be in this business as an assistant. I don't think that you would be able to buy an outdoor unit without being a refrigeration technician or working for an A/C company. I would suggest that you let a professional install this for you because of the EPA regulations involving refrigerant and the necessary specailized equipment for installing (ie. guages, refrigerant, and vacuum pump). Hope this helps.
depends on your ability to "sweat" in the lines. yes, you can buy the unit. no-you can't buy the freon-which you'll need... at least some. but the main thing is to sweat it in properly with no leaks, with the dryers, and should do a vacuum on it. (must for the waranty) and the cert. is need for removing the old freon if it has any.....don't know your particular skills... but it's possible...just not likely. --maybe ask a miatenance man from some apartments who knows what he's doing, and offer enough $ --still less than a contractor...but without the warantees that would go wityh it.
