please help w/gas heater
Old 09-28-01, 01:49 AM
P
Smile
I just bought a house and had the gas turned on. My 4 y.o. Coleman hot air heater will not fire. When I turn up the thermostat, the blower starts, the igniter glows red but no ignition because no gas comes out. The heater just shuts down after a minute or so. Can anyone give me something simple to check before I incur more expenses?
Thanks for your help.
Old 09-28-01, 10:45 AM
PDF
Make sure
gas valve is set to "ON",not pilot or off.If these prove true you should replace ignitor.It is the least expensive item to replace.PDF
