Need to maintain boiler systems at constant temperature?
Old 10-18-01, 02:04 PM
Guest
Question
I recently had my boiler system cleaned and the contractor said that boilers need to be maintained at constant temperatures...they don't "like" to be turned down to a cooler temperature at night, it causes to much stress on the system (changing heat all the time). What is the stress that is caused on the system?
Thanks,
Old 10-19-01, 10:14 AM
PDF
Does your boiler
also incorporate a loop for domestic hot water?Or do you also have a seperate hot water heater?PDF
Old 10-21-01, 03:17 AM
PDF
I take it
you are turning heat down by your wall mounted tstat.This would leave boiler at a preset temp of around 180 degrees.The boiler in this way cycles itself.You probably shut it down completely at the end of heating season.PDF
