blower fan
Old 03-22-02, 11:00 PM
mcburns
blower fan
My blower works great and continuous when the A/C is on but not when the heater is on. It's a combo unit and uses the same blower. When the heat is on, the blower will run for about five seconds, switch off for about 15 seconds, on for 5 seconds, etc. I though it might be the relay switch, however, I should have the same problem with the A/C. Any suggestions?
Old 03-23-02, 05:13 AM
PDF
Could be relay
Your combo unit runs high speed for a/c and a slower speed for heat.This is done thru a relay.Does fan run okay if you place tstat to fan "ON" and then turn heat on?How old is unit?Does it have a solid state board?PDF
