central air
Old 03-27-02, 05:28 PM
nypkh
central air
I am looking to install a central a/c system in a ranch house with hot water heat. Can you give me any advice or resources to research ducting?
Thanks
Old 03-27-02, 08:12 PM
rclhvac
goto http://www.hvaccomputer.com/main.asp
Down load the 40 dollar program and do a load calculation on your home - it will also give you the duct sizes base on the calculations
Old 03-28-02, 01:33 PM
nypkh
Thanks, I've already looked into that program and plan to use it. I'm more concerned with the transition from the air handler to flexible ducting, how do I accomplish this?. Also, can I run all the supply ducts off of one trunk or do I need multiple trunks for differrent diameter supply ducts?
I have experience with large vehicle (bus) climate control, but not residential.
Old 03-28-02, 01:48 PM
rclhvac
How many sq ft is your home?
How many rooms to cool?
Old 03-29-02, 11:05 AM
ahasbeen
Can't recall for sure but you might check with an HVAC supply house and ask if one of the rigid ductboard manufacturers, such as CertainTeed or North Bros., have a flyer on their products that would show different design configurations or layouts. Your a/c system is not going to be any better than its duct system. Wish I could tell you where to go on the internet
Old 03-29-02, 01:53 PM
nypkh
The house is approximately 1700 sq/ft including part of a basement I also need to cool. 6 rooms on main floor + 1.5 bath. One large room in basement.
