Fan Run Continuously - Heat Pump
Old 04-03-02, 01:08 PM
ybnrmlharry
I have a heat pump and the fan mounted on the furnace portion runs continuously. The thermostat fan is on "AUTO" position and the cool/off/heat is in the "OFF" position. The only way to stop the fan is to turn the breaker off. Since this is not a gas heater I do not believe there is a switch like in the other examples. It seems to me that the problem would be in the printed circuit board or the thermostat. Suggestions?
Old 04-03-02, 03:41 PM
A
Hey,
Check your fan relay it could be stuck closed.
Old 04-05-02, 10:19 AM
ybnrmlharry
In fact I have now checked the t-stat and the relay. After moving the relay the fan went off but the next cycle of the heat the fan remained on again. I am in the process of getting a new relay. Thaks.
Old 04-05-02, 08:01 PM
A
Hey,
I'm glad you found the problem and I appreciate the feed back.
