Fan runs, compressor doesn't
When I turn my thermostat to AC and lower the temp, the fan comes on and runs continuously. The compressor does not run. Once yesterday the compressor came on. Today I tried turning the unit off a while, then turning the AC on with the thermostat set low and then turning the AC on with the thermostat set high and after it is on run the thermostat down. No luck.
