Ice
Old 04-16-02, 09:02 AM
ramcat
Question Ice
I opened my A/C unit to find ice on the coils and compressor. I did this because I wasn't getting much A/C. Using the hose, I cleaned off all of the ice and cleaned out the inside of the unit. I also changed the filter. What caused the ice? Can I expect this to occur again when I turn on the unit? I'm keeping the unit off all day to make sure it is defrosted. The unit is a Heil model PA 95
Old 04-16-02, 11:02 AM
Mike Swearingen's Avatar
Cool
I'm not an HVAC pro by any means, but usually ice is due to poor air flow, low freon, etc.
If you've cleaned the coils, have you had the freon checked?
Mike
Old 04-16-02, 12:39 PM
Wuzzzell
Lightbulb
Check your indoor coil--it could be dirty--this will also cause ice.
Old 04-16-02, 02:39 PM
ramcat
ICE
Haven't had the freon checked yet, but I have noticed that the fan keeps running even when the A/C is turned off at the tstat.
Old 04-16-02, 06:57 PM
Wuzzzell
Exclamation
Either your t-stat is in the on postion for the fan, or you'll need to check your fan relay to see if it is stuck shut.
Old 04-18-02, 08:26 AM
ramcat
It seems the problem was in the wiring. For some reason, a short developed between the hot wire (RED) and the Compressor (YELLOW). Luckily, there was an extra wire (BLUE), so I exchanged them and everything works fine. Thanks for all the suggestions.
