Modulating Thermostat
Old 05-11-02, 09:03 AM
Is a modulating thermostat available for electric basebord heating units?--This is my conception of such a system----The modulating thermostat would increase or decrease the D.C. field of a saturable reactor as the themostat deviated from the set-point so that the A.C. output voltage to the heaters would be proportional to the set-point deviation.When the thermostat deviated from the set-point because of a drop in room tempearture the output voltage would increase.An increase in room temperature from the set-point would decrease the output voltage.
Old 05-11-02, 09:24 AM
hvac4u's Avatar
sounds similiar
to they way a pnuematic t stat works, check honeywell, johnson controls, if you have a cc dickson supply house near you they could tell you
