Heat Pump Problem
Old 05-14-02, 03:53 PM
Comit
Question Trane heatpump blower shuts off
Have a trane heat pump. inside blower shuts off but compressor keeps running, for hours sometimes, then coils freeze up. compressor will not shut off with thermostat.must use breaker. to turn on the blower must use breaker. Then it will work fine for a while. Had it serviced many times. they said the thermostat is ok. Said it was a bad firestat. replaced it many times. touching the wires together sometimes would make it come on. Next service they disconected the firestat. worked for a few months now it is doing it again. any idea what is could be?
Old 05-14-02, 05:33 PM
hvac4u's Avatar
sounds like
the contactor sticking in the o/d unit
Old 05-16-02, 04:17 PM
Comit
Question
what is the o/d unit?
Old 05-16-02, 04:30 PM
hvac4u's Avatar
o/d
is outdoor unit, the condenser. it has a coil inside the contactor that pulls in the points, energizing the unit, they may be stuck, see similar thread for PDF'S advice
