dropped something in ac/heat vent
Old 05-15-02, 03:25 PM
kel4jay
Help! dropped something in ac/heat vent
I managed to drop plastic wrapping and a wrench down the second story bathroom's a/c-heating vent while installing a filter. Is there any way to get these back. Also, will this be a problem if I turn on the a/c or heat?
Old 05-15-02, 06:29 PM
ahasbeen
About all you can do at this point is run the fan and check to see if the wrap is sucked up to the coil or into the blower squirrel cage. It won't get any further than the coil. Check often and you may find it.
Old 05-15-02, 06:38 PM
hvac4u's Avatar
filter
will probably catch it if is where it should be, before the blower and coil. if in supply duct, will reappear at register, retriveal depends on accsessbility of duct.
