A/C Freezing Up
Old 05-26-02, 02:00 PM
eswan
A/C Freezing Up
My airconditioner is not blowing cold air. I went out to look at the unit and there is ice all along the pipe. Insulation is missing in places and ice forms in those spots.
I realize this is probably an easy fix, but I am lost HELP!!!
Hot in Houston.
Old 05-27-02, 05:44 AM
PDF
Turn a/c off
place fan to on for 2 hours to defrost unit.Check air filter and cooling coil behind filter.If these are dirty or plugged,the reduced airflow MIGHT be the problem.Unit could be low on gas.Do the DIY items first.PDF
