High Efficiency furnace exaust vents, How to keep animals out?
Old 05-30-02, 05:19 AM
Carz n Compz
We just had our 18 year old furnace replaced with a new high effinency one. The old one used to run up thru the exaust cap on the roof. They closed the vent and now only the hot water tank goes to that vent. They drilled 2 holes and put PVC pipe from the new furnace to the outside beside the A/C unit. How can I keep small bugs and animals out. I will send you some pics if you want when I get back from work. Just post or PM ur email addy.
THX
Old 05-30-02, 09:30 AM
jonathanisaac's Avatar
Old 05-30-02, 01:07 PM
Carz n Compz
That name is origanal? Who else would think of something like that?!
Old 05-30-02, 03:00 PM
Lightbulb
Old 05-30-02, 05:00 PM
Carz n Compz
I hate to by so rude but if you have the answer post it ok? Dont ask questions unrelated to the post. Yes I am from TCM? You are the same one also I am sure if you know me from TCM.
Old 05-30-02, 05:02 PM
hvac4u's Avatar
on topic
supply houses will sell you a "birdscreen", but i recommend hardware cloth, as long as the holes are big enough to not restrict the airflow
Old 05-31-02, 01:59 PM
PHnd
Leave the pipes alone! They are not made to have an external screen installed. There is one built on the furnace. If you obstruct the pipe in any way it will cause problems, void warranties and could be hazardous. If there is one made for that furnace, you will have to get it from the furnace mfg. and no where else.
I've installed many, at ground level, cieling level and through roofs without a problem.
