a/c unit starting problem
Old 06-02-02, 08:19 PM
kksingh
I have central a/c. My cooling unit is outside the house. When I set the thermostat to cooling it does not start. Where should I start looking. Is there any web site that tells how the system works.
Thanks in advance.
kksing
Old 06-03-02, 06:07 PM
hvac4u's Avatar
be sure
high voltage is present, many thing will cause this, need more info
Old 06-04-02, 09:54 AM
mnnhk5
My outside a/c unit did not come on when set on cool air due to a 'relay' gone back. The relay only cost around $12 and is inside the outside a/c unit.
