A/C Blower on low . . . want High
Old 06-14-02, 08:20 AM
mbach
My Tempstar A/C unit seems to blow on the low (heat) setting. How do I switch it to the High setting. The "brain" was replaced after a thunderstorm last year.
mbach
Old 06-14-02, 08:50 AM
Jay11J's Avatar
You will have to look at your wire diagram to see if your blower has 3 or 4 speed.. and see if you have a tap for high speed on the contorl board. If you have both, than tap the high speed from the blower wire together.
