central air
Old 06-23-02, 03:21 PM
cass00
Unhappy central air
our air is not cooling ever thing is running but the air coming out is no longer cool do we need freon ?
Old 06-23-02, 05:58 PM
mike540
Check a few more things.
Three things should be running. The indoor fan, the outdoor fan, and the compressor.
Both coils should be clean. The indoor coil and the outdoor coil.
Your filters should not be clogged and your vents, both supply and return should be open and unblocked.
When your system is running right and working properly the indoor unit should be blowing cold air, the outside unit blowing hot air, the large refrigerant pipe will be cool to the touch and the small refrigerant pipe should be slightly warm to the touch.
Enjoy the Journey
Mike
