no power on thermostat for heat pump
I replaced my heat pump themostat for a programmable one but nothing , not even the fan will work. I reinstalled the old one (weatheron), still nothing worked. I checked every wire in the thermostat and none of it has any power. I have turned all circuit breakers to on and check the fuse in the attic furnace. The heat pump is only 1 year old and we haven't used it for several weeks. . It is 95F and the AC service guy I called won't be able to show up soon enough. What can I do myself? Thanks a lot!!!
