no power to furnace or central a/c
Old 07-04-02, 01:42 PM
mythicdani
Unhappy no power to furnace or central a/c
i have no power to my furnace which means my central air isnt working either i replaced the fuses one was blown a/c worked for 1 day then stopped again i have a janitrol furnace 5 years old and a/c is 2 years old the diagnostic light wont even help with no power at all to furnace . furnace stopped working a few monthes ago but the blower worked so a/c worked then it just stopped suddenly. please help its real hot in here.
Old 07-04-02, 02:16 PM
lynn comstock
Try the fuses again.
Look at the fuses for discolorization, bluing of the brass ends. Discolorization is evidence of overheating due to a loose connection. The clips may not be holding the fuse tightly. This will cause fuse failure.
If the fuse is discolored, the clip will be heat damaged as well and the springiness of the clip is gone. A new fuse clip of disconnect box will solve the problem.
