air Conditioning problems
I need help, My fan on the outside compressor stopped turning so but there is a loud humming comming from the unit. I the got a spatula and spun the fan and the compressor kicked on. The fan and the compressor turned on but there is cool air comming out from the vents. I then went outside to check the cooper lines and they are not cold they are trhe same outside tempreture. Can you give me any idea what the problem is.
Thanks, AL
Thanks, AL
hey al
sounds like the condenser fan or cap has gone south, and if the unit is not cooling with it and the compreser running, i would suspect the compressoe has gone bad as well. can you give us some presures?
