approx repair cost
approx repair cost
I have a 5 ton York unit that needs a compressor. I'm wondering if i should fix it or replace the condensor unit. What would an approx cost be for a new compressor, refrigerant and labor?
Junk it
In most cases it's cheaper to replace the whole system.
Be SURE to have a heat load calculation done, 5 tons could be too big causing the unit to cycle on and off frequently.
This cycling is what eats up compressors
