logging in
Old 12-06-03, 05:08 PM
mrhaney
logging in
i belong to this group but where do i go to login at. usually on the main page it says login but i do not see it. i had to type in the keyword login to get in. there must be an easier way.
Old 12-06-03, 06:22 PM
kaybyrd's Avatar
mrhaney,
The login area is at the very bottom of the main forum page. If you hit the page down button several times you will get to it. Another means to get logged in is to hit the USER CP button in the top row of buttons on the main forum page. It will tell you that you either need to register or login, then proceed on to the login.
If you are on a private computer you can go into your USER CP (Control Panel) and change the settings under EDIT OPTIONS to log you in automatically when you return to the site. This requires that you allow cookies with your browser.
Hope this helps!
Kay
