Workboots
Old 05-17-05, 02:40 PM
Hirsch's Avatar
Workboots
Does anyone know of a store that sells size 16 mensworkboots that does mailorder? It is a nightmare trying to find them.
Old 05-17-05, 05:10 PM
the_tow_guy's Avatar
Winter's over, Hirsch; store those snowshoes!!!
Or go here:
http://www.milbinoc.com/workboot.htm
Old 05-19-05, 02:42 PM
Old 05-19-05, 04:24 PM
You can type 'size 16 work boots' into your favorite search engine and come up with several websites, such as http://www.2bigfeet.com/mens_work.php
Old 06-01-05, 09:53 AM
Hirsch's Avatar
I really do need a shoe that big. I am 6'5". The boots may have to wait a little while. Next paycheck is probably going into my truck for rear brakes, tires, and a transmission fluid change to see if that cures the transmission leak ( also, no clue how old the transmission fluid is). Dontcha just love vehicles?
Old 06-01-05, 01:52 PM
Hey Hirsch,
If you think it might be over 100K on that tranny fluid, think twice about replacing it to cure a leak at this point
Most often older, gunkier, high-mileage fluid is stopping leaks
If the fluid has say...120K on it, there's a good chance a fluid change at that point would make it leak more
You're better off leaving it in there
Not that you shouldn't get the leak fixed, or change the fluid regularly...It's just you said hopefully it'll stop leaking after the unknown mileage fluid is changed
Usually that's not the case with high mileage fluid
Usually it leaks more
Old 06-06-05, 05:01 PM
Red Wing shoes, up to 18 EEE
Old 06-07-05, 04:13 AM
mattison's Avatar
Believe it or not, Red Wing also has a program for people with two different sized feet. I saw it in their catalog, so if your left foot is a 16EEE and your right is a 9E then they can fix you right up.
Old 06-11-05, 02:59 PM
Amputees can also purchase a single shoe from a Red Wing dealer.
Old 06-13-05, 01:08 PM
Hirsch's Avatar
Finally got my other Dodge truck home on Friday. It was going to be a parts truck, but am seriously considering making it a daily driver. It does need some work like cat back exhaust, however, I do have a new pipe in the bed and no brakes. MAster cylinder is dry so I will add brake fluid and bleed the system. The truck I am driving now loves stalling, uses a pint of tranny fluid a day now, needs exhaust work and has no brake lights (wiring issue), needs tires too and brake work, new drums and shoes. Thinking about selling that one for parts since I do know someone who may have an interest in the bed or just yarding it after I take off the bed.
