zero-reference voltage
Old 05-17-06, 09:55 PM
bolide's Avatar
In thread:
Originally Posted by nap
you see your post calls for attaching all to XO. well XO also is to be grounded (earth ground). See what happens when you do not ground XO.
During normal operation, absolutely nothing bad or detectable happens if that's what you mean.
Give a procedure by which you can determine from typical electrical diagnostic instruments whether X0 is grounded.
You can't do it. So stop posting your effluvium.
X0 is grounded to guard against high-voltage upset such a high voltage line contacting a low voltage line accidentally. It has nothing to do with providing a zero-reference point or stabilizing voltages in normal operation.
Old 05-18-06, 12:41 PM
nap's Avatar
nap
nap is offline
New Member
Didn't say anything bad happens under normal operations but yes, something "detectable" does happen.
Tell me what type of X-former you have handy to play with and how many X terms it has.
You can't do it.
Yes I can
Old 05-18-06, 01:42 PM
bolide's Avatar
So what's the problem? You can't reference to earth? How is that a problem?
Obviously we are talking residential in this forum, so three.
Old 05-18-06, 02:22 PM
nap's Avatar
nap
nap is offline
New Member
I see nothing referencing this as a resi forum, merely electrical.
Do you actually have a transformer that you can connect as desired?
And if you can complete my test, you will see why referencing to earth is important and makes the job simpler when working controls.
Apparently I am not the only one that does not see that this is a resi specific forum:
http://forum.doityourself.com/showthread.php?t=264420
Old 05-18-06, 04:18 PM
bolide's Avatar
What does DIY mean?
How is that relevant?
Your response needs to be something that any electrician can verify for himself.
> If you can complete my [stupid] test, you will see why referencing
> controls.
Just explain it.
Then we'll see whether you have anything worth testing.
That person was just asking a question out of curiosity, it was not a DIY question.
Sure, we get lots of commercial inquiries.
But the thread about a neutral is DIY residential as is 95% of the material here. When answering a DIY residential question you should not bring up issues that are irrelevant.
Just stick to the residential scope where you made your "See what happens when you do not ground XO [sic]" challenge and tell us what happens.
Old 05-18-06, 04:37 PM
nap's Avatar
nap
nap is offline
New Member
What does DIY mean?
> controls.
Just explain it.
If you do not have access to the proper situation (transformer that you can "play with") you will simply apply your logic and say that I am wrong. I can prove it to you but am not going to waste my time if you won't prove it to yourself. You seem to be the "seeing is believing" type of guy.
BTW: the neutral thing, it applies to commercial/industrial as well. It is relevant to all electrical installations.
So let me know when you have a transformer available.
If you want to learn what I am speaking of, I will oblige but you need to can the [stupid] remarks. If you want to continue with your "I'm right because I said so" rhetoric then we'll end this here and now. It's no sweat off my back.
BTW; I happen to know commercial business owners that are DYI'ers. They can get very in depth. Don't discount the website. It is a good source of info for all.
Old 05-18-06, 04:45 PM
bolide's Avatar
No, I'm a "there better be a rational explanation" type of guy.
So you should have no problem explaining it in a residential context that everyone can follow.
Most people do not.
Let's see whether you can propose something rational.
Perhaps someone will make the test.
If you present a rational explanation, there's no need to test it as far as I am concerned.
It should stand on its own merits.
You have pretty much gutted your claim already. So all that remains is to see your allegedly simplified test procedure made possible by earth-grounding X0 at the pole.
We're waiting to hear how this simplifies testing.
Do you also know the meaning of "[sic]"?
Old 05-18-06, 05:21 PM
bolide's Avatar
When trying to troubleshoot an ungrounded system, you will read different voltages from each "hot" to earth ground at different points in a system
If it is truly ungrounded, you will read 0V at all points because there is no pathway for current.
Because on earth it is not usually possible to avoid all conductive/coupled paths, you see phantom voltage readings with high-impedance instruments.
If the system is ungrounded, using earth ground as a reference is illogical.
However, referencing any other ungrounded conductor to X0 (or to another conductor) is perfectly valid (which is what one actually does on a grounded system; the fact is immaterial that X0 is earthed).
Old 05-18-06, 05:29 PM
nap's Avatar
nap
nap is offline
New Member
. I do not propose explaining anything. I am prepared to have somebody prove it to themselves. Actually I have already told you what will happen, I was simply going to tell you how to prove it
I have already told you et.al.
Most people do not.
actually most electricians I know do. You just have to think about it for a few minutes and I'll bet you do as well
As already stated, I have given you all the info needed, you will not accept this so we are down to "the proof is in the pudding"
I have "gutted" nothing and I said nothing about earth grounding "at the pole". I specifically stated you would have to be able to have total control of the connections. Ground it only when required to do so per the activities requirements.
It is not used to simplify testing in a typical residential setting, although I suppose if the proper situation had developed, it would through those with no knowledge of what will happen into a tizzy and scratching their heads.
Why yes I do. It is generally used to refer to a misspelling within a quoted passage to inform the reader that the misspelling is an actual misspelling by the author. It is taken from the latin word "sic" which translates to the English term "thus". When used in a passage it is not used to replace the misspelled word but generally placed within brackets, as you did, to refer to the previous word. When you placed the word "stupid" within the brackets in my posting, which is what I was refferring to, was used in a manner to impute your thoughts into my statement, so therefore your question of ," do you know the meaning of [sic]?, is a meaningless question in regard to any of my posts as I neither wrote [sic] into any of my posts nor was reffering to it in any previous post of mine.
Did I pass your test??
If you want to have a battle of wits, do NOT come without a weapon.
Old 05-18-06, 05:35 PM
nap's Avatar
nap
nap is offline
New Member
Wrong. You do not need current to read voltage.
Of course, even if you conduct your experiment from a hot air balloon it is not really possible to avoid all conductive/coupled paths; thus you see phantom voltage readings with high-impedance instruments.
Sounds like a fun experiment. I have no real idea what you are trying to infer here as the only conducter that would interfere with what I propose would be the wild chance that a plasma miracuslously developed in the area.
It proves a point though. It proves MY point. It is not for use in application, it is a discovery of theory.
Wrong again. I can prove it but you won't take the challange.
Old 05-18-06, 06:14 PM
bolide's Avatar
Voltage that is incapable of sustaining current is not useful for residential wiring. Phantom voltage readings won't operate a lamp.
> I have no real idea what you are trying to infer here as the only conducter [sic]
> that a plasma miracuslously [sic] developed in the area.
Let's rule that out.
Let's just hear what you propose would be observed at a typical residence if X0 was not earthed.
In other words, it is impractical and useless.
> I can prove it but you won't take the challange [sic].
Please set forth exactly what it is that you claim could be proved.
Specifically, you stated, "See what happens when you do not ground XO [sic]". You did not state what will happen.
You stated only that nothing bad will happen in normal operation.
> I was simply going to tell you how to prove it.
That is what I am asking you to do.
Set forth your claim of what can be proved and proceed to explain how it can be proved.
So what exactly do you mean when you state "See what happens when you do not ground XO [sic]"?
You need to set forth your claim precisely as to what is connected where.
> of the connections.
That's fine. Be precise about where it is to be grounded.
Trackbacks are On
Pingbacks are On
Refbacks are On
