Calculatiion Conundrum
Old 04-01-10, 05:17 AM
I am trying to calculate Square Ft. Of course its simple enough, even for a guy like me I did this using Excel and came out with different answers
Someone please, tell me what I'm doing wrong
A room measures 10ft 6in X 10ft 3in or as otherwise stated 126 in X 123 in
if
126 lin in x 123 lin in = 15498 sq in / 144 = 107.625 sq ft
my formula says =sum(in x in)/144
then how does
10ft 6in X 10 ft 3in = 101.5 sq ft
my formula says -sum(ft x ft)+(in x in)/144
Have I misplaced a () ?
Old 04-01-10, 05:42 AM
Good morning, I think you just need your coffee.
then how does
it doesn't
Not sure how you're multiplying feet and inches times feet and inches, but 10.5 ft X 10.25 ft = 107.625' same as above.
Try the coffee black . I won't share my brain fog episodes.
Bud
Old 04-01-10, 07:04 AM
Nevermind. Bud said it. Give him all the glory.
What is odd is even if merlesdad mulitplied 10.6 X 10.3, that would not be the number he posted either. So maybe he simply rang up the wrong number when he was multiplying. But that too strikes me as odd because if he got different answers, wouldn't merlesdad have done the calcs all over again to be sure?
So where did merlesdad go wrong? I might be thinking about this all day now, rather than concentrating on my work. Somehow or another he used numbers less than 10.1 X 10.1. ???????
Maybe merlesdad should Google this all-time prize winner: "The case of the missing dollar". LOL
Old 04-01-10, 08:21 AM
Thanks ecman51, I need all the glory I can get .
So you concentrate on your work, I know how to re-create his answer, but not his thinking.
His second equation is wrong, my formula says -sum(ft x ft)+(in x in)/144 but even that doesn't give his answer. However, if you divide the (in x in) by 12 instead of the 144, you get 1.5, thus the 101.5 wrong answer.
Bud
Old 04-01-10, 09:14 AM
It must have been that recurring flashback.
the issue at hand was being able to use feet and inches not
a decimal equivelant if inches.
to do that All I had to do was change the formula
=sum (feet X 12 + inches) X (feet X 12 + inches)/144
all this effectively does is convert the lineal feet to inches, then add the inche measurment.
Thanks to all who helped.
