New Job....
Old 12-12-15, 05:56 AM
lawrosa's Avatar
Super Moderator
New Job....
Just an FYI
Well I have a new job and am kind of out of residential plumbing for the most part. I don't have to deal with homeowners... yay!!! LOL
I got a brand new 2015 truck and threader and my sole job is to tap the gas meters and run a line to residential generators..
So I may not be as active as I once was and I may be a weekend warrior here. Ill try to do the best I can here to help with any and all plumbing related questions..
Old 12-12-15, 06:04 AM
Congratulations on the new job Mike! Having a company truck can be nice - it's kind of like a raise all by itself
Old 12-12-15, 06:31 AM
Temporarily Suspended
Congrats on the new van. That's what I need.
Old 12-12-15, 07:05 AM
Congratulations Mike the new van and job are great. I do hope you can still be on the forum as often as your plumbing advice has always been valuable. I don't know what I would have done if I hadn't had your advice about that shower with the grab bars you told me about. Too bad big Orange doesn't sell it anymore as it is a great shower for the elderly.
Old 12-12-15, 07:56 AM
ray2047's Avatar
Sweet little van, even sweeter job. Congratulations.
Old 12-12-15, 07:59 AM
Handyone's Avatar
This looks like it could be a pretty sweet gig.
I'll try to help out in finish plumbing but not much good at venting and the technical aspects.
Old 12-12-15, 10:14 AM
Tolyn Ironhand's Avatar
Congrats on the new job! I need a van like as I am working out of an E250 Ford van and I am 6'5" tall. Not a lot of head room.
Old 12-12-15, 10:31 AM
A street ell on fuel gas? Is that allowable these days? I remember when street ells, bushings and close nipples were prohibited for both gas and oil fuel piping.
Old 12-12-15, 11:13 AM
lawrosa's Avatar
Super Moderator
Bushing are not allowed here in NJ...
I dont typically use st ells but the guy that showed me how the company does these or whants them done uses them and passes inspection.. So I do what they tell me,.. LOL
But know that you brought it up I am going to check the gas code now..
Old 12-12-15, 11:33 AM
lawrosa's Avatar
Super Moderator
All I could find is this in the NJ FGC
404.3 Piping in concealed locations.
Portions of a piping sys-
tem installed in concealed locations shall not have unions, tub-
ing fittings, right and left couplings, bushings, compression
couplings and swing joints made by combinations of fittings
And this for cast iron pipe only..
5. Cast-iron fittings:
5.1. Flanges shall be permitted.
5.2. Bushings shall not be used.
5.3. Fittings shall not be used in systems contain
ing flammable gas-air mixtures.
5.4. Fittings in sizes 4 inches (102 mm) and larger
shall not be used indoors except where ap
proved.
I cant find nothing else regarding that joel..
Have a look see ..
New Jersey Fuel Gas Code
Old 12-12-15, 01:43 PM
I trust you, Mike. As I recall, this issue came up a few years back and upon checking the National Fuel Gas Code, I found that the prohibition against street ells and maybe even close nipples had been removed. I still won't use them, or bushings, in fuel work, gas or oil. I'm just old fashioned that way.
Old 12-13-15, 07:05 AM
chandler's Avatar
Is all the iron piping necessary that close to the origin? Granted we have only propane and the gas company runs yellow copper from tank to generator. Is it different with NG? Or could they run flex from the meter origin to the application?
Old 12-13-15, 08:32 AM
lawrosa's Avatar
Super Moderator
Its 1/2 psi so you need larger piping then propane. Cant run poly or CSST outside. Poly is underground and CSST in the home only..
Must hard pipe in NJ with Galv pipe outdoors..
If the gen was farther off the house then I would dig and install poly with 2 risers...
Old 12-13-15, 08:53 AM
Handyone's Avatar
This is what I think also, regarding the street ells. Just a guess, but I would think the prohibition was lifted due to the increased quality in castings compared to many years ago.
Concerns were poorly cast or poorly tapered/loose threads, a weak point at the neck where male threads start, and even sand holes from the casting.
Old 12-13-15, 11:08 AM
ray2047's Avatar
Mike, just wondering do they give you a jobs per day quota? Tried that one time and quit after a week. Couldn't do a good job and meet quota.
Street ells: Once installed water lines in a bathroom. Bigbox was close so used their (Asian) street els and other fittings. None would hold water. The street els were the worst. You could hand tighten to within one thread of the last thread.
Old 12-13-15, 12:53 PM
lawrosa's Avatar
Super Moderator
One gen a day ....,,,,,,,,,,,,,,,,,,,,,,
Old 12-13-15, 01:36 PM
ray2047's Avatar
One gen a day
Oh man that is a sweet job.
Old 12-13-15, 01:38 PM
I had a recent experience with a 13KW Generac set up on a Home I had For Sale because the Seller was delinquent on his Mortgage. It was about 100' from the house (and the propane tank) sitting on a nice concrete pad.
As he approached foreclosure and eviction, he claimed that the Generac had been struck by lightning and was destroyed so he removed it. Surprisingly, the Stainless Steel Double Door Fridge and the Jenn-Aire Range also became defective in that same time period and had flown the coop before the Bank gained possession.
Any chance of that Generac's destruction by lightning being legit ?
The Bank didn't question the disappearance . . . . they were just glad he vacated without more of a fuss.
Old 12-29-15, 07:19 PM
lawrosa's Avatar
Super Moderator
some of the harder jobs I did.. Still having trouble with the final conections to the gen without havong too much of a swing joint..
Caught a cold today as I was soaking wet and muddy working in the trench on the last pics..
Uggg...
Today...
Old 12-29-15, 07:22 PM
Nice work. Very neat. Are you required to paint the exposed gas lines gray like around here ?
  #21
Old 12-29-15, 07:24 PM
lawrosa's Avatar
Super Moderator
only have to paint the threads with zinc paint in NJ
Trackbacks are On
Pingbacks are On
Refbacks are On
