Removal of FAKE stained glass
I was wondering if anyone knew how to remove fake stain glass effects that have been painted on a front door (on top of the glass) it looks like it's peel and stick or something for the metal effect, but the glass parts look like jelly that's been painted on and hardened... It's gawdy and I want to remove it..does anyone have any suggestions?
Thanks!
Thanks!
Perhaps a heat gun or blow dryer and a razor blade scraper would remove the faked stain glass if it is a peel & stick product. Fake stained glass paint removal, if not removable with razor, may require paint remover. Avoid getting remover on adjacent surfaces. Take care not to scratch glass with razor blade.
removing painted on stained glass
If your project is on something that you can remove as in a window, take it to someplace with ventilation and use paint thinner. Works like a charm-also using a straight edge razor takes off even the worst sun baked on "lead" strips. Goo-B-Gone works too, but takes longer. If you use it, leave it on for at least 1/2 hour before trying to scrape.
If the
If the
Imcbride, welcome to the forums! You know you are talking to ghosts, right? This thread is 8 years old, and hopefully they got their problem solved.
